Frigidaire Front-Load Washer(Model#FWT445GES2): Found the rear tub bearing is out and the middle tub seal leaking water.
You can either replace the complete outer tub assembly with the bearing already installed or if your really into a challenge just change the bearing alone as described here:
http://www.applianceblog.com/mainforums/threads/237-FIXED-Drum-Gasket-and-Rear-Shell-Bearings
Manufacturer part number 131525500 is RepairClinic item number 407639
Rear outer tub assembly with bearing and shaft seal
Also order the tub seal:
Manufacturer part number 134146100 is RepairClinic item number 936915
