GE Range(model#JSP26G0N2WH): Right-Front top surface element burner(8″) not working.
I put my volt meter in the element terminal block and got a reading of 240 volts. That indicates its getting the proper voltage, but won’t turn on, because the element is bad.
Here’s the 8″ Right-Front Top burner element for this model:
Manufacturer part#WB30M2 is RepairClinic item#2797
