2000 Sears Kenmore Range made by G.E. (Model#362.75205891): Oven won’t work, the glow bar wouldn’t glow orange at all to let the oven valve start releasing the gas flow into the burner. I found the oven igniter glow bar was out, tested it with my ohm meter, found no continuity through it. Also I check to make sure the glow bar igniter was getting 120 volts, and it was. I installed a new glow bar igniter.
Part#WB13K0021
Oven igniter assembly
2494
Connector may need to be cut off & wires spliced to range wiring with porcelain wire nuts.
Have a good evening and weekend!
Area Forecast For: South Willamette Valley
Tonight: Showers likely in the evening…then a chance of showers after midnight. Cooler. Lows 30 to 35. Southwest wind 5 to 10 mph.
Sunday: Mostly cloudy in the morning…then partly sunny. A chance of showers. Highs around 45 light wind.
