MeatWrench
Got a ‘52 shelvador. All original except rewired with 14 ga. It ran before I rewired it but it has been jostled around a good bit as I refinished the exterior and cleaned it up. I plug it in and the start windings run the compressor for about 2 sec then the relay clicks and nothing. Lesser clicks occurs every few seconds while power remains applied. Ohm thru the compressor yields very very low resistance. 0.3 ohm from both the start and run windings. Those values seem nonsensical to me. No short to ground. I have jumped out the thermostat and get the same results. I don’t know if the click is the overload circuit or if it is the PTC relay going from start to run. Any ideas before I pursue replacing the entire system? Should I have used 18 ga wiring? Could a poor wiring termination (I used ring terminals) be the cause?
Part B. Any words of wisdom as far as replacing the compressor etc goes?
