10 year old Kitchenaid Microwave KCMS1555SBL2 started arcing
rbon
california
KCMS1555SBL2
I have a 10 year old KitchenAid microwave (KCMS1555SBL2) which is installed as a built in with a 24in trim kit. Even though the unit has been kept super clean, today it started arcing for the first time while making popcorn. The arcing seems to be coming from the waveguard/magnetron area. The magnetron cover is super clean but I cleaned it again as well as the whole interior and tried again--still arcing. I even took off the waveguard and cleaned underneath. I have ordered a new waveguard/cover to see if this resolves the arcing.
Here is the issue: I can't seem to find any good quality microwave which will fit in the cubby we have and which will also accommodate a trimkit--today's trim kits have different dimensions. The net size of my cubby itself (disregarding front cabinet trim which can be removed or cut back) is 17.125" deep, 15.75" high and 25.5" wide. I am trying to repair this old microwave because it fits in this space nicely with the existing trim. Is it worth doing so? Is it likely to be fixed by putting in the new waveguide/cover or not? Assuming the answer is no, do you have a recommendation as to a small good quality microwave which would fit in this enclosure?
Added complete model number
KCMS1555 is just a partial model, please post your complete model number.
I just asked Rick if he could help you, I don't work on microwaves.
Check the mag tube antenna for any burned or scorch marks:
rbon
california
Hi: Here is a photo of the mag tube antenna. Does this look like burned or scorched to you? If so, what should I do? Thanks
rbon
california
here are 3 more pics and I hope they are better. thanks, Rick
