- 106.45433800
- Sears Kenmore
- More than 10 years
Kenmore elite: 106.45433800
Auger motor: 2322580
I've pulled the motor and hooked up 12V to it and it turns both directions. I measure 80 Ω resistance across the outer pins.
I tried measuring voltage on the harness when the lever is pressed and it comes back +/- 40 VDC depending on cubed or crushed.
Is there a more conclusive way I can test the motor? If it's not the motor, any advice on further testing or locating the board that is powering it? I'm not sure if it's the board in the panel on the front of the door or elsewhere.
Lastly, under the front panel is another panel bolted to the door. After removing the bolts, the panel wouldn't budge if anyone has advice on how to remove it.
