Myfridge01
- 106.50042712
- Sears Kenmore
- 1-5 years
I recently read another thread about my same model making weird noises like a pump malfunction when dispensing water. I need to go one step further…about 2 weeks ago, I changed my filter with a brand new oem cartridge. Everything was fine until 2 nights ago. The water started to trickle and it made those stuttering noises.
That’s when I found your thread about that similar problem and the answer was just to replace the filter. You spoke about an automatic bypass with it out to see if there was a water line problem. I pulled the filter out and pressed the dispenser. Water came out just fine. Strong steady stream. I put the same brand new filter back in and the problem started to happen again.
How can I tell if my issue is the same? I don’t want to replace the expensive filter I just bought with another one if at all possible! Could there be another issue?
I forgot to say, my ice maker seems to be working fine.
Any guidance would be appreciated! It’s only a couple years old!
