106.51713411 Kenmore coldspot ice maker not dispensing ice
coberste
I have an Kenmore Coldspot (model 106.51713411) and the ice maker has stopped dispensing ice. The motor is running but the dispenser isn't working. Any ideas?
You mean the ice maker is not making ice? Or the auger motor is not dispensing ice out the door? Either way it sounds like you may have broken wires underneath the freezer door causing this problem. This has been very common on this model.
Lots of members have found frayed and broken wires causing the ice maker/and or auger motor to be dead. Remove your bottom kickplate grille, Remove the black wire harness loom too, broken wires can be underneath it.
Another member was having a similar problem here: FIXED: GSF26C4EXY02 Whirlpool Gold Ice Maker Problem Look at his post #6 he found frayed and broken wires underneath the freezer door, remove your kickplate and check for that first.
Here's another one with the same thing about the frayed and broken wires: FIXED: 106.51173310 Kenmore elite ice maker not working - no led light
Here's another: FIXED: Whirlpool WSF26C2EXF01 Door Icemaker Not Working
