106.51763510 Kenmore Fridge ice maker issue.
Appliantology
Michigan
Model: 106.51763510
Ice Maker fill hose keeps freezing up, replaced the water valve and bypassed the water filter. still freezing up.
may need a tech sheet or wiring diagram. I'm thinking there's a heater circuit in there, can't chase it down for the lack of a tech sheet & wiring diagram. Any help would be great! Thanks in advance!
I can't locate it, Did you look for the tech. data sheet? Its either behind the bottom kickplate grille or under the right side UPPER door hinge cover.
I can ask our tech. bigbuck if he has it.
Appliantology
Michigan
No, It's not on the unit, I looked every where. Thanks for taking the time! If you find one let me know, I'll keep digging...……..
Thanks bigbuck!
Yes, I see your fill tube heater. On your User Interface board, You should have 14 Volts DC Output at J2-1(white wire) J2-8(blue wire).
Ok, good find, what's the customer going to do now since its NLA?
