106.52203100 Kenmore Coldspot constantly needing to be manually defrosted and not cooling
eholcomb19777
Missouri
My Kenmore Coldspot has been having the coils in the freezer get iced over causing the fridge and freezer to not cool properly. We can turn it off and defrost it ourselves and it will start working again for a week or so until it gets frosted up again. What is possibly causing this and how can I test it and fix it.
Model # 106.52203100
One of the defrost components is out. Remove the evaporator cover and check the defrost heater and the defrost thermostat for continuity. The defrost thermostat needs to be below 40*F to show continuity. Check that while it's still frosty before you defrost it again. If the defrost heater and thermostat check good the control is bad.
Here's a link for the heater and thermostat however, the control has been discontinued and is no longer available.
Defrost Thermostat WPW10225581
Defrost Heater Assembly WP2323197
