Shelbast20
- 106.54536400
- Sears Kenmore
- 6-10 years
We just moved into a home and the Kenmore 106.54536400 made ice after cleaning and turning it on. It smelled and tasted bad so we took everything out again to deep clean. We let it all dry before replacing in the freezer and since then it doesn’t make any noises like it’s trying to make ice or doing anything. Visually I can see that the ice tray has a small amount of water in where the cubes are made but it’s not even half way filled. What would cause this? Or what should we check/replace?
In addition... We got the smell out, but the water still doesn’t taste well after changing the filter. Is it possible the water lines have mildew in them and need to be replaced or cleaned? (The fridge had been off when we moved in.)
