- 106.54609300
- Sears Kenmore
- More than 10 years
Water coming out through bottom of freezer compartment. Took back off and found tray and coils full of ice. Thawed out and poured hot water down to make sure drain was clear. Worked fine for 3 or four days and then ice in bottom of freezer under bottom basket. Freezer and refer. cooling fine. Thought it was the Defrost timer and purchased one, and a thermostat. Cannot find the location of the timer. Have looked in back by compressor, in the front toe kick and up under the electronic control panel in the refer. I do not remember seeing in behind the freezer back panel, could it be there? When I ordered the part by the model number, it gave a part # W10822278. I am wondering if this Elite Model has a control board instead of the timer. Strange, that if that were so, it would not come up as an option when searching by model number. I could use some help finding location of the timer or determining if my model does not have a timer. Any other thoughts what the problem is if it is not the timer? Thank you, and this is my first post, so hope what I have asked is acceptable and complete enough.
