FIXED 106.56534400 Kenmore Refrigerator warm water from the dispenser,
barry potts
orlando fl
the ice maker is working but the water dispenser outputs small amount of cold water then warm water.
That's normal Barry, you have a water tank in the refrigerator section and it only holds a small amount of chilled water, if you continue to run the water dispenser after the chilled water is depleted it will be warm water until it chills down again when your not using it.
barry potts
orlando fl
Thank you for your reply, I understand what your saying and that is how it was, the amount of cold water was less than a small glass, thinking about this when I'd had time to think this problem started after I changed the water filter so I replaced the filter again and it seems to be back to the way it was.
Again many thanks for your prompt reply.
Barry Potts
How long ago did you replace your water filter?
Here's the water filter for your model:
Water Filter EDR3RXD1
barry potts
orlando fl
8 days, when I removed the suspect filter it was much heavier than any filter I have changed after it had been installed until the indicator turned red, so my guess I fitted a bad filter.
Yup, that sounds like it to me too.
You should have a warranty on it, contact where ever you bought it from and have them send you another new one.
