106.56826600 Kenmore coldspot no ice need help
Freds ride
In house
Kenmore coldspot ice maker problem
no ice no water have 120 volts to ice maker but when I jump it out nothing no water no rotation?
need help.
thank you
Do this test below and let us know the results:
Step#1: Open the freezer and view the status LED
(STATUS LED)
2 BLINKS FOLLOWED BY 1 SEC. DELAY(REPEATED)
POSSIBLE CAUSES: The flapper door on the emitter is blocking the beam or the optics are faulty.
Step#2: Press the emitter flapper to unblock the optics beam
(STATUS LED)
POSSIBLE CAUSES: The optics are faulty. Replace the emitter and receiver boards.
If the LED is ON steady: The optics are working properly.
Here are the optics boards you can order, they come together in 1 kit with instructions and video:
W10757851 Cntrl-Elec
Freds ride
In house
Good morning.Replaced optic board light is on
replaced ice maker
checked power at ice maker getting 120 volts
stick jumper wire in ice maker does not cycle new or old ice maker
also jumped out water on ice maker and no water or sound or Click of the solenoid.
Is there a fuse in the ice maker?why when I install jumper wire no movement of ice maker/water valve?
need help
thank you
You do have a in-line thermal fuse, but if that was bad then you would not be getting 120 volts at the ice maker holes L and N on the ice maker module head. Is that where your putting your multimeter probes when testing for 120 volts?
Here's the in-line thermal fuse:
Harns-Wire
The in-line thermal fuse is the black wire that's hanging down from the wire harness.
Freds ride
In house
Yes true, I have a meter And check continuity between the thermistor or thermostat
not sure what you call it and it rings out?
Freds ride
In house
Can I jump black on wiring harness to brown?
what will that trigger
I am assuming
black hot
white neutral or return
brown ?
green with yellow stripe ground
is this correct
No, you can't jump any wires.
Did you take the volt reading from the test holes on the ice maker module?
WPW10190961 Icemaker
