FIXED 106.59069994 Kenmore Coldspot hot between the doors
needhelpl
Bryan, Tx
The strip is hot between the doors. I looked in the back, the fan wasn't running. pushed it and it started turning. Didn't last. I pulled the bottom front off and vacuumed. Waiting to see if cools down. IF it doesn't as I feel no air moving from the condenser area, What part do I actually need to replace and where is it located? THank you
You'd need to replace the condenser fan motor.
Here's the condenser fan motor for your model you can order:
833697 Condenser Fan Motor Kit
There is a video that shows you how to replace it when you click the part link to it.
needhelpl
Bryan, Tx
Hi Jake- I got the part finally installed a few minutes ago. Plugged in fridge and it is so quiet we are thinking, "oh great, now it won't run at all" well the lights are on when you open the door. So, is it suppose to run constant or just come on when needed?
Thank you!
It will only run when the compressor and inside freezer fan is running.
Is the compressor and inside freezer fan running?
needhelpl
Bryan, Tx
Good morning Jake-
Thank you for your quick response. Everything is working perfectly!
Thank you so much!
Excellent, glad to hear the new condenser motor fixed it. (y)
