106.70834100 Kenmore frig/freezer not cooling
tab a
ks
This frig/freezer 106.70834100 has the compressor (fairly hot) and both fans running, but is not cooling correctly (40 degrees in freezer). Coils are clean. I measured R134a pressures and see about 1-2 on the low side and about 150 on the high--which seems like it should be about right, from my reading. What doesn't seem right is that the pressure with the compressor off, is around 35, with an ambient temp of around 75. I'm used to seeing static pressures about the same as ambient, at least on my cars.
Would you suspect it's low on gas? If so, I can vacuum, look for leaks, and recharge.
Sounds like an inefficient compressor. What does the frost pattern on the evaporator look like?
That's exactly what I was going to ask too Rick. LOL
Look at the very bottom photo below and that is a NORMAL FROST PATTERN:
tab a
ks
Finally had a chance to get back to this and check it. Not surprisingly, it looks like a sealed system problem--small amount of frost on upper tube. This doesn't help me much, with figuring out my initial question though--am I low on gas, or have a bad compressor?
tab a
ks
Ok. Would low on gas look different, what makes you say compressor?
Thanks.
