110.10502999 Kenmore Washer - overfill
Jspen
Worcester ,ma
I I have a Kenmore washer model number 110.10502999. So I replaced the metal clips that hold the upper ring to the tub. I put washer back together. Started load and washer over fills. I checked the pressure fill switch and it works properly. I blew into it and water stops filling. I checked the tube from bottom of tub. No leaks. I'm not sure if something is stuck in the tub but water will not come up and shut off the switch. Will just keep filling. Flooding out my house. Any suggestions? Can I take out the tube and see if there is any obstruction in the bottom. Thanks in advance
