thecoconutlord
Kenmore 110.20222510 washer, started acting odd and not draining. Fiddling with the lid lock and restarting it would get it to drain, until there was no response from the board.
Replaced the board (W11106376), got part way through a cycle till I heard a pop, board fried. Replaced some wiring, another CB, and realized the board fries right before the drain cycle. Replaced the pump and the board again, problem solved!
Thanks for this thread:
www.applianceblog.com
FIXED - MVWC400XW Maytag washer keeps blowing resistor on control board.
So this washer stopped in the middle of a load and lid would not unlock. Lid lock light just flashed. Stored codes were for lid lock switch and for the shift actuator. I replaced both parts and it did not fix. Pulled out the board and there was a large resistor R050 that was cooked...
