110.20922990 Kenmore (Whirlpool) 90 Series Washing Machine Making a Grinding Noise
BigPhoneDaddy
Chicaho
I just finished repairing my Kenmore (Whirlpool) 90 Series Washing Machine that stopped agitating. I found that Motor Coupling was bad and just replaced this evening as well as the Clutch, just in case.
I replaced with the following parts:
Motor Coupling 285753A Whirlpool OEM Part #285753A
Clutch 285785 Whirlpool OEM Part #285785
Now the machine spins and agitates, but makes a grinding sound when it does into the spin cycle.
What else should I be looking for?
Thank you, BPD
Missing some digits...
Where is my Model Number? | Appliance Aid
Was the noise there before your repair or just after your repair? Have a recording of the noise?
Something in the pump, loose tub nut and drive block, gearbox are common for being noise makers.
BigPhoneDaddy
Chicaho
Kenmore 90 Series Washing Machine
MOD: 110.20922990
SER: CK 2296192
TYPE: 111
Noise was after the repairing the clutch and Motor Coupling. No other broken parts or pieces and everything is clear in the pump and motor area. Everything was moving with no issues. Problem (grinding noise) is only when in the spin cycle.
Should at least recheck those repairs then as the best place to start...
[video=youtube;9K1KHEogf3c]https://www.youtube.com/watch?v=9K1KHEogf3c&feature=player_embedded[/video]
[video=youtube;tVc6SZ2DD4U]https://www.youtube.com/watch?v=tVc6SZ2DD4U&feature=player_embedded[/video]
Does the noise speed up, stay the same, slow down, etc, etc?
BigPhoneDaddy
Chicaho
I rechecked the clutch and Motor Coupling and all look and work. Motor Coupling is spins freely and the Clutch it tight to the had.
When running, it's good in the fill and agitate cycle. When in the spin, it starts up and the grinding noise start and then it appears that the hestitates and tries to stop. Could it be Transmission/Gear box? I'm think that this what caused the Motor Coupling break in the first place with it seizing up.
Any thoughts?
