110.25102310 Kenmore duet 500 washer lidlock
Ronmyers68
Pleasant hill Missouri
My washer was starting cycles over and over. I ran the diagnostic and was told it was the lid lock switch. I cannot find one locally. I tried putting my old one back in and it doesn't work at all now. Is there a way to bypass this. Any ideas on a temp fix?
Hi, No unfortunately there is no way to bypass it.
Do you mean The cycle starts over in a continuous loop? If so, I found a service bulletin on this problem. I posted it in post#2 here: FIXED: WTW4900BW0 Washing Machine, starting by itself, continuous cycles, etc
Here's the lidlock switch assembly for your model:
Door Lock W10404050
Also, check your door strike to make sure that's not broken. That's the part that goes into the lidlock switch when you close your lid.
Here it is for your model:
Door Strike WPW10240513
