110.25102311 Kenmore Washer buzzing
washang1
Charleston
I was in the middle off the wash cycle and it started buzzing. I’m thinking I may have overloaded it. Any suggestions for this fix?
Take everything out of the machine and start a spin/drain cycle then start over and don't overload it.
The most common cause for service calls. Too many times will result in an expensive repair. (unless it's a 50 year old Maytag, you can't kill those machines...lol)
If that doesn't fix it I'll need a model number. Kenmore model numbers are all numbers and look like this: xxx.XXXXXXXX
Can you tell what's buzzing or where it's coming from? Is it coming from the console? What's working, what's not working? Can you start a wash cycle?
washang1
Charleston
It seems to be coming from the bottom. It's not washing or draining. When I’d put it on the spin/drain cycle it filled with water, after it filled up it started buzzing again.
