110.25132410 Kenmore washer won't spin
slinglemouse
Florida
My washer stopped working when it reached the spin cycle. After performing the Diags and after seeing that it wouldn't spin at all and determining the cause, I replaced the actuator assy. With the new part, it still failed the spin test although it at least started and tried to spin. Further diagnosing revealed that the +13VDC on J2-4 was actually +12.36 DC. Is that within range or does that mean my control board needs replacing also?
I'm attaching your tech. data sheet below,
Get into the diagnostic and post the fault code or fault codes you get.
Page 2 of your tech. data sheet do: ACTIVATING THE SERVICE DIAGNOSTIC TEST MODES
Then do FAULT CODE DISPLAY MODE on Page 3
Then you can see what fault code/codes you are getting on Page 6 and Page 7: FAULT/ERROR CODES
