Redbullmoo70
- 110.25132411
- Sears Kenmore
- 6-10 years
Recently, our washer seems to not be spinning or draining correctly on any cycle, even the drain and spin cycle. Sometimes after running a wash cycle, the spin light remains on and the lid is unlocked as if it has completed the cycles (the complete light is not on). When we check the clothes they are still soaking wet and we can literally ring water out of them. We'll close the lid and move to the drain and spin cycle. The washer will begin by spinning very slowly and you can hear that there is still a lot of water in it. The drain will come for a bit and it will try to spin again.
This will repeat for a few times before the cycle sometimes seems to figure itself out and eventually spin very fast without the sloshing sound and make the clothes suitable for the dryer. There are times where we have to run this drain and spin cycle a few times before it works well enough to dry the clothes.
We've ruled out unbalanced loads by rearranging the load in between drain and spin cycles and ultimately the drum doesn't seem clunky or the washer isn't wobbling much. Even when the drain pump is running, it very clearly is still pumping water out but will shut off before trying to spin again.
