110.26832690 Kenmore Washer 80 series won't run
Jonnyp
Iowa
My kenmore 80 series washer flooded the laundry room. It was the hose that connected to the switch. Now it will not run.help
110 is just the 1st three digits of your model number, we need the COMPLETE model number first before we can assist you. The model number tag is located under the lid.
Which hose to which switch?
Jonnyp
Iowa
Model number is 110.26832690 and it was the hose that connects to the water level switch
Make sure all the water is out of your tub, then take that hose off your pressure switch and blow through the hose, then blow through the nipple of the pressure switch and listen for a clicking sound.
If you hear no click sound when you blow into the pressure switch, then its bad.
Here's the water level pressure switch for your model:
Pressure Switch W10335056
