110.26842692 kenmore 80 series - won't fill or agitate, but will rinse and spin
bmillertym
Placentia, CA
Hi, My washer won't fill or agitate, but when you turn the dial to rinse or spin it will run that portion of the cycle. When you put the dial on any wash cycle it does not fill and does not make any noise. I replaced the Timer 3 years ago and thought it may need replaced again, but after putting the new timer in, the same problem still exists. I would rather repair than buy a new unit, since the new ones seem to be cheaply made. Any ideas to fix?
Start a wash cycle and measure the voltage at the fill valve. Set it on warm and you should have 120 VAC at both coils.
Water Inlet Valve 285805
Video Included in part link on how to access it.:)
