110.26902690 Kenmore series 90 washer made rat a tat noise and now won't spin
edbranch
california
Hi, My series 90 washer made a noise (rapid repetitive metallic noise between cycles) and now will not spin. I removed the motor and coupler looks good.
Is it the clutch?
Do you see the silver clutch turning when it should be spinning in the spin cycle?
You'd have to jump the lid switch so the washer will spin in the spin cycle, this link shows you how to do that: Bypass Direct drive washer lid switch from consol plug
The silver clutch is just above the gearcase.
If its not turning, your gearcase is shot.
Here's the gearcase for your model you can order(Video Included in part link):
3360629 Neutral Drain Transmission
If the silver clutch is tuning and if your motor coupler looks fine, then you'd need a new clutch. Whenever I replace the clutch I always replace the basket drive assembly as well, as they both work together.
Here's the clutch for your model:
285785 Clutch Assembly
Here is the basket drive assembly for your model:
W10820043 Basktdrive
Videos to replace each part are included on each part page.
Anytime!
