110.27052602 Flooded Kenmore Oasis washing machine
Ed Degnan
RI
Hi, My basement flooded when I lost power and my sub pumps stopped working. My washer sat in about 8 inches of water for several hours before I could pump the water off. Now after I start a load I am getting an F51 error code before it even senses the load height. I have googled the code and it seems like it could be any number of issues. Does anyone have a specific suggestion. Thanks in advance.
Hi Ed,
You likely got water in the RPS and stator, they both sit closest to the floor.
ERROR CODE F51: There is an intermittent connection at the Rotor Position Sensor, (RPS), causing the electronic control to indicate an F51 code.
This is the part you will need to order:
Rotor Position Sensor W10183157
