110.27082604 Sears Kenmore Oasis Elite Washer - Error code LD
Billpa2020
LD code suddenly appeared during rinse and spin cycle. I’ve read that it could be an object stuck in bottom of basket, blockage in pump or a bad pump. Unit 15 years old. Insight appreciated. Thanks.
Hi Bill,
Error Code LD=Long Drain
I always first check for a clog or foreign object in the drain pump, that will cause no drain/slow drain/grinding noise in the drain pump.
You may also want to check the rubber hoses that attach to it, seen items get stuck in there as well.
Drain Pump W10536347
Watch this video to access/replace it:
