110.28002011 Kenmore washer will not spin
Adbeckwith
Amarillo
Will not spin. Changed the belt. It worked for a few days then stopped spinning again. I calibrated it. Did diagnostics and nothing. When it does get to the spin cycle it starts to click a few times and then the timer changes from 8 to 16 and water starts again
Does it drain all the water first?
Put the washer in DRAIN/SPIN and tell me what it does. Give it time to go through that cycle even if it pauses stay with the machine.:)
Where does that clicking noise come from? You get no fault code in the diagnostics?
Since you changed the belt and it worked a few days, I'm thinking it may be your splutch that may be worn out.
Take the belt off and remove the transmission pulley and remove the plastic cams and see if the teeth are worn down there, If so order and replace that Splutch cam kit.
Here's the splutch cam kit for your model:
W10721967 Splutch Cam Kit
Video included in part link.
