- 110.28132411
- Sears Kenmore
- 1-5 years
Greetings all I have a Kenmore 700 series washer that I have had for 2 years.
Push start, the door latch engages, the washer starts the load sensing process (both drum and agitator turn), the washer goes to wash cycle (wash light comes on), then the machine goes to load complete with no wash done at all and the washer does not fill with water.
I noticed that the door latch does not disengage and I have to unplug the machine and plug it back in to get the latch to release.
I ran the diagnostic test and it returned the F7E5 code which points to the shifter. I checked the connections underneath and it appears the the wires are connected and in good shape.
I ran the manual testing mode program where you can individually select cold water fill, hot water fill, slow spin, slow agitate, etc. Neither the cold water fill nor the hot water fill worked, I selected slow/medium/fast agitate and the impeller would turn but the drum would not. I selected slow/medium/fast spin and the impeller would turn but not the drum.
I checked the water inlet valves for resistance and they all were in the 980 Ohms range, I checked hoses, filters, and water pressure and everything seemed fine.
I am inclined to replace the water inlet valve but the F7E5 shifter code gives me pause. If the machine detects an issue with the shifter will it not fill with water?
I appreciate any help.
