110.29522800 Kenmore 500 model washer won't complete wash
nosaj
Florida
I have a Kenmore 500 washing machine on normal cycle it will only finish a cycle if I put in a half a load of clothes. A Full load and it will not finish.
In the older ones I believe the wig wag mechanism is what my dad would have me change out .
Anyone point me in a a direction. Got a DMM and can test what's needed. My exp quit right before direct drive machines which I believe this one is.
Any help is much appreciated,
Jason
nosaj
Florida
model is 110.29522800 type 111-07
Jason
Also I have bypassed the lid switch.
Thanks Jason,
I need more detail, when you say it will only wash half loads what does it do in full loads? Does the timer keep advancing? Does the timer stop advancing, if so where does it stop at?
Do you hear any noises when it won't do full loads?
nosaj
Florida
Full loads it will stop during agitate and just sit there. On Permanent press or any other type on the dial it will run all the way through. no odd noises.
Stops where? Immediately after it starts agitating? Does the timer still advance? No sound at all when it does that?
If you try to advance the timer a little bit does it start running again?
And this just happens on full loads? That's what is throwing me a loop, if there was a problem with the timer it should do it on any size load.
nosaj
Florida
After speaking with my Mother in law
Normal model will run till agitate mode, drain and quit on spin. She will take some clothes out and it will finish up.
Jason
Ok Jason,
Its the basket drive you will need to order and replace.
Here is the basket drive for your model you can order(Video Included):
W10820043 Basktdrive
