TonyCA
- 110.45089
- Sears Kenmore
- 6-10 years
Hi Jake. How loud is the "click" made by the CCU? I have a similar HE4t washer (MOD 110.45089404) that worked fine before we left for a three week vacation but now is exhibiting similar "no response from START button" behavior except I am able to successfully run the diagnostics test and the small button/plunger/other on the door switch is NOT broken.
I went so far as to remove the door switch assembly, remove the harness connector to the switch, and use a DMM/voltmeter to verify that pressing the button/plunger/other closed the switch (i.e. provided continuity between the contacts). From your assistance offered to others, I'm assuming maybe my CCU is bad since I do not hear a click when I power the washer, but neither did Dana (member "Danvix").
Also, I do hear a beep when I power my washer and have full functionality of my control panel (i.e. can switch between various wash cycles and can successfully run the diagnostics test), I simply get no response from pressing the START button. Thoughts?
Thank you!
-Tony
Thank you!
-Tony
