FIXED 110.47511701 Kenmore Washer won't start.
bsaucer
Alabama
I can power up the washer, and select a cycle, but when I press start, nothing happens. All other buttons respond when I press them. I can put it in diagnostic mode. It displays F24, but after I press the button several times, it goes through a complete self test. I believe F24 indicates the temperature sensor, but that reads 9.9K ohms.
I thought you meant the start button wasn't lighting up either?
Do you still have the F24 Error code?
bsaucer
Alabama
The (stored) F24 only showed up when I first entered diagnostics mode. After fixing the start button, I was able to run cycles as normal.
Ok, sounds good.
