110.61202011 Kenmore Dryer heats up but timer don’t move
tnvolsluvr
chattanooga
Dryer gets hot but timer don’t advance. Also takes forever for clothes to dry.
Does the timer NOT advance on AUTO DRY or TIMED DRY?
If you start the dryer on a TIMED DRY cycle about 40 minutes will it continue through the cycle and shut off when it gets to 0 minutes? If not your timer is bad.
Here's the timer for your model:
WPW10186032 Timer
For the forever taking clothes to dry that's usually a vent restriction. Air flow restriction are the Number 1 cause of this issue!
Pull your dryer out from the wall, then remove the exhaust hose from the back of your dryer, then Dry a load with the vent hose off and see if it DRYS normal, if so you found the problem.
Also check for a exhaust vent restriction to the outside of your house, also go outside and check the air flow coming out of the vent, I see lint clog that outlet as well. The air flow coming out should be quite strong.
