110.61202013 Kenmore Dryer doesn't heat in auto mode but does in timed mode
toggle
United States
My Kenmore Model #110.6120213 doesn't heat in auto dry mode, but if I put it on time dry it heats fine. Would this be the moisture sensor? Since it does heat I am assuming it is not part of the heating element, thermal fuse, or thermostat that is broken?
Corrected model number
Model Number 110.6120213
I can find no listing for such a model number. The closest model I found was 110.61202013. Can you please double check it.
toggle
United States
Sorry I posted the right number in the model section but not in the actual post. You are correct for the model number, it is 110.61202013. For some reason it won’t let me edit the original.
No, I don't think so. I think a moderator edited your message and changed it there without noting that the alteration had been made.
On model 110.61202013, the sensor and electronic control look to only control advancing of the timer, not heating. From the wiring diagram I can only see the timer being responsible for your symptom.
LINK > Kenmore 110.61202013 Dryer Timer
It might be possible to confirm the timer malfunction. On both Auto and Timed Dry the contacts between timer terminals C-B and C-A should close. If either tested open (no continuity) when the timer is set to the Auto setting, it would usually confirm a timer fault.
toggle
United States
Ok that's great I have a multi-meter and can test that. Do you know an easy place to find the diagrams you are looking at so I can take it apart and find the parts you are referring too?
Sorry, I forgot to note it that I fixed your model number.:)
Watch this video, it will show you towards the beginning:
Let us know how it goes.:)
