110.65132410 Kenmore Dryer heat works randomly
Sean1307
Ohio
Dryer will heat on high heat for timed dry but not on low or medium heat. It won’t heat on the “more dry” setting.
So it won't heat at all in the Moisture Sensor Cycle at all?
Then in TIMED DRY on LOW and MEDIUM it heats on HIGH or no heat at all on LOW and MEDIUM?
I'd first pull the dryer out from the wall and see if you have lint build up in the exhaust hose and also go outside your house and check for lint build-up where the hot air exits your house.
