110.66914691 Kenmore 90 series dryer won't start
Tausch
Detroit
Hello all,
I'm brand new to the blog but I'm having trouble with my Kenmore dryer. It's a 90 series, model 110.66914691 type 138--00. I found that the dryer just won't start. It doesn't make any internal noise when I push the start button, however the laundry we had in there appears to have gotten a little warm prior to me discovering that it was dead. I checked the fuse box and everything seems good there. I also vacuumed out all the dust and lint that had accumulated around the machine. Please let me know if anyone has any ideas. Thanks!
Corrected model number
Missing some digits.
Could that be 110.66914691 ?
LINK> http://www.applianceaid.com/model-number.php
A copy:
Q - My dryer is dead, what could do that ?
A- Common problems...blown house fuse/tripped breaker ( electric dryers need 2 )...loose white/neutral wire...broken belt ( on some models only )...door switch/door switch bracket...*thermal fuse open ( venting needs attention )...broken or burnt wire...timer...motor...burnt power cord/plug...start switch ( especially the ones with a built in relay switch )
* If you find a blown thermal fuse, always clean, change, adjust the venting system and vent hood first
