- 110.67732794
- Sears Kenmore
- 6-10 years
Hey all, I have a Kenmore 70 series electric dryer model number 110.67732794 . I've done a couple repairs on it already in this saga so I'll go through them below. To summarize though, when I press the Start button, I hear the hum like it's trying to start, but it doesn't kick into motion with spinning or anything.
First off, before doing any testing at all with a DMM etc, my partner had recommended we replace the thermal fuse as that was a common issue with these dryers. I replaced that, still had the same result afterwards.
Then I got a DMM out, tested connectivity and everything looked good for the thermal fuse, the start button, the door latch. When I turn the timer to say... 30 mins, I do indeed hear it ticking. And as you'll read in a moment, other repairs momentarily made the dryer work so I'm not sure whether or not the timer is suspect at all.
At that point, I took off the back panel entirely and noticed the right-most power connector had the wire melt completely through the insulated sleeve and some burning on it. I had assumed that the power cable was at fault, picked up a new one at home depot, swapped it out, and YES the dryer worked!
I ran one load of clothes to dry overnight. I babysat it for 30 mins, and everything seemed fine, heat was being produced and vented, etc. Went to bed. Woke up, and the dryer is back to not starting (just humming when Start is pressed), and it seems like the clothes didn't make it to the end of the dry cycle as they were still a bit damp.
Any ideas here? Am I looking at potential motor issues or some other more obvious thing I need to test with my DMM?
