110.75102310 Kenmore Series 500 gas Dryer no heat
theodo155
Indiana
Dryer starts, drum turns but no heat. Worked fine the day before.
A copy:
Gas Dryer Troubleshooting
Quick Gas Dryer Tips:
Problem -
Gas flame comes on first few times then quits and igniter keeps cycling on and off but never lets the gas go.
Answer ( most common ) -
Replace the coils on the Gas Valve.
M Series Ignition Coil Set used on many Whirlpool/Kenmore brand gas clothes dryers since 1984. Comes with both the three terminal Boost/Hold and two terminal Secondary coil
Problem -
No flame, no igniter glowing at all.
Inspect igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter when dryer should be calling for heat.
Silicone Carbide Igniter Kit with ceramic holder. Used on many Whirlpool/Kenmore brands gas clothes dryers
http://www.applianceaid.com/gas-dryer-troubleshooting.php
