FIXED 110.76912692 Kenmore dryer won't start
firedive
usa
Won't start no light, checked thermal fuse, it had been bypassed, put in a new one still no power
Your model# says the dryer is gas, thermal fuse is for the heat only and not the dryer running.
You will still have to check the broken belt switch, door switch, outlet plug, etc.
Q - My dryer is dead, what could do that ?
A- Common problems...blown house fuse/tripped breaker ( electric dryers need 2 )...loose white/neutral wire...broken belt ( on some models only )...door switch/door switch bracket...*thermal fuse open ( venting needs attention )...broken or burnt wire...timer...motor...burnt power cord/plug...start switch ( especially the ones with a built in relay switch )
If you get the dryer running again, this will have to be put back in correctly.
firedive
usa
I have already replaced the thermal fuse that had been bypassed, it ended up being the door switch bracket and a blown light.
Thank you for your support
Tim
Glad that was all it was, thankx for the update :)
