edee_em
- 110.82832100
- Sears Kenmore
- More than 10 years
I posted earlier thinking I had a problem with a thermistor in my dryer. The thermistor was not the issue as it tested (resistance not continuity for thermistors) good and all other thermostats etc tested good. I also tested the windings on the motor and they were within spec. What I did notice, after total disassembly of the dryer is that the motor was pretty covered in lint. I vacuumed off what I could but then took the motor out and took it outside to blow it out with my air compressor. The dryer has been working on all heat settings and is no longer shutting off mid cycle. Looks like the motor was overheating (total guess on my part) and shutting off.
While this issue was not able to convince me to buy a new washer/dryer set my latest issue may force me to do just that.
I have a Kenmore washer (He3t) and dryer (He3) set from the turn of the century (I love saying that!). The door handle of the dryer came off in my hand the other day. When I took the door apart to get to the handle screws for replacement I noticed that a lot (3 out of 6) of the plastic posts that accept screws that hold the door outer frame (plastic) onto the inner door frame (metal) have broken rendering them useless to hold the screws again. The posts for the door handle are okay.
I was thinking that I would need to "rebuild" these posts using something (help) or somehow (help). Bondo, plastic, ???? keeping in mind they would have to hold screws. Would longer screws work? Double sided tape? Anything? Thoughts? Thanksr
