edee_em
- 110.82832100
- Sears Kenmore
- More than 10 years
I recently took apart my he3 dryer (110.82832100) for another issue and cleaned out all the accumulated lint from everything and everywhere. It was running fine until today when the dryer stopped at 5 minutes remaining on a normal setting using auto cycle. I heard a distinct "err click err click" noise as it stopped. It was still hot in the drum as the cool down cycle didn't happen and the timer continued to run down. At 0 minutes, the clothes dry light lit up and the end of cycle signal beeped as normal. I've noticed that this only seems to happen when it is at Normal heat setting. When I run it at Delicate settings it seems to operate normally. Wondering if that means anything to anyone.
Along with that issue, I noticed that there was quite a bit of lint in the cabinet which was puzzling as I had just cleaned it out a week or two ago. The lint screen is okay (as far as I can tell) but I did notice that there is a seal attached to the front panel where the lint screen fits into which I'm assuming would sit against the lint filter. As I'm typing, it struck me that it might be there for the lint duct to seal it. Anyway, I thought to replace it but looking at the sears parts diagram, I am unable to locate the part number. Would ordinary weather-stripping/seal work in this case? Thanks.
