110.87087601 Kenmore HE5T dryer no heat
browntiger
So dear wife complains that something wrong with a dryer 110.87087601
First no heat, opened cleaned up. Check cutout ok, high-limit ok, at 73F thermostat 10k, exit thermistor 56k.
Ran it, we have heat, now she is stating 50 minute cycle runs for 90 minutes but the clothes are dry at 50 minutes.
Go into the diagnostics mode: F31 is displayed.
Can I ran some sort of automated test in the diagnostics mode?
Can I clear that F31? I replaced thermistor may be 5 years ago? Not sure how long it keeps this?
Could it be moisture sensing? How can I diagnose them? If I put a wet towel - they buzz in a diag mode.
Anything else I can test...
Rick I think your looking at the wrong tech. data sheet, I'm attaching it below.:)
F31--->L2 Line Voltage Error
F:31 flashes if a low voltage condition (less than 30 V) has been detected. This fault code appears ONLY when in the Diagnostic Test Mode.
--->Check to see if a household fuse has blown or a circuit breaker has tripped.
--->Confirm the power cord is properly installed and plugged into the power outlet.
--->Check the relay connections on the electronic control.
By the way @browntiger we need to know what the final outcome on your previous thread was.
Please update it here:
  • techsheet-w10110637-revb.pdf
I must have marked it wrong. Thanks Jake!
Anytime Rick!
