110.92195500 Kenmore topload washer will not spin unless helped to get started
cdromce
tacoma, wa
hi guys i have a old kenmore top loading washer that is giving me fits. problem is replaced clutch assembly and transmission with oem parts as washer was making horrible grinding and stopped spinning. Now i have a weird issue. After agitation cycle the washer goes into spin cycle but will not always start to spin without my spinning it to get it started.
Once it gets going it stays going, both the clutch and transmission are brand new oem put in today, could the motor be going bad as it agitates fine but will not spin unless helped to get started. have inspected coupler and agitator and as i said i have replaced the clutch and transmission with new parts. the model is old an kenmore digital #110.92195500. i also thought maybe they sold me a clutch that is not for a large capacity washer. any thoughts.
The part you forgot to replace is the basket drive, that is what is causing this problem, seen this many times when I worked as a Sears Tech.
Here is the basket drive for your model(Video Included):
W10820043 Basktdrive
Glad to help.
