FIXED 110.94832201 Dryer gas LP takes very long to dry the clothes
epofsanjose
Saratoga CA
I had this dryer for about 4 years and just move, so I converted from Natural Gas to LP since I get my gas out of a tank in the backyard. It had a leak, very small leak, so I changed the gas valve and added the kit for LP. Now it works, but it takes very long to dry the clothes. I notice that the burner stays on for 4 seconds at a time, then it turns off. I change the coils to the new valve, still the same, please provide suggestions to my puzzle to keep the burner going longer, rather than turning on for such small amount of time.
With the exception of the dryer toe panel are all other panals in place/installed?
Tried the dryer with the vent attached and the vent disconnected from the dryer?
epofsanjose
Saratoga CA
Jeff,
Youtheman!!!!!! Disconnected the vent and the heater stayed longer, heat up and dried the clothes. The pipe has too many elbows, should I shortened it and make it "L" shape? Directly to the vent outlet in the wall? Then reconnect the vent pipe?
Thank you
Epofsanjose
epofsanjose
Saratoga CA
Jeff,
Thank you very much. I shortened the pipe and put just one elbow, connected it to the wall outlet and turned it on. It works perfectly now, thank you again. You provide a great service.
Sincerely,
Erwin
Thankx for the update :)
