FIXED 110.95087401 Kenmore elite Dryer He4 not working
Slikrik450
Joliet
My kenmore elite He4 dryer mod #110.95087401 is not working. It all of a sudden started beeping and blinking the control locked light nothing else lights up on the panel. I opened it and found lots of moisture on the inside even though those clothes I thought had dried since I had started the dryer yesterday. It’s humid here the last few days and the vent on the outside sometimes sticks open so I’m not sure if my clothes never dried or if humidity from outside got in there. I unplugged it and tried again but nothing.
Help please!
OK, remove the top ( 2 screws behind the top panel). The electronic control board is on the left side. Make sure the door is closed and check for 120 VAC across P1-3 and P1-5. This is the same as yours:
44211
OK, you'll need to check the belt switch for continuity. With the top off see if the belt is broken. It should be tight around the drum. The belt switch is mounted to the motor bracket.
This is probably a dumb question but did you try to unlock the control? I assume you did.
Slikrik450
Joliet
Would that cause the control panel to do nothing when you try to press any buttons? And of course I tried to unlock the control. Lol
Thank you!
OK, I might not have understood you correctly. After unplugging the machine and then restoring power, do any lights on the console turn on? Can you select a cycle?
Slikrik450
Joliet
So the only light that comes on is the blinking control lock it blinks and beeps. Won’t turn off, won’t do anything else cannot select a cycle or anything. The light inside comes on as well.
OK, unplug the machine and access the main control board, Disconnect then reconnect the P3 and P4 connectors on the board. Make sure they are on all the way then try it again.
Slikrik450
Joliet
Oh yes did that several times. I thought you meant something different. Still just blinks and beeps.
No, This guy AllFixed made a few comments and that screwed you up. Go back and read post #12
