110.96281100 Kenmore dryer - thermal cut off fuse, why?
paulmars
house
Why is it needed? Ive only repaired a few dryers, but this looks like extra part. This dryer has the std High-Limit Thermostat, Operating Thermostat, and Thermal Fuse. However, it also has this Thermal Cut-Off Fuse. This Thermal Cut-Off fuse is located in the heater housing where it feeds the drum and looks more like a thermostat. Its also the most expensive part.
279769 Thermal Cut-Off Kit
See attached diagram. ( )
#1 Thermal Cut-Off Fuse
#34 High-Limit Thermostat
#42 Operating Thermostat
#59 Thermal Fuse
kenmore 110.96281100
tks,
pa
(age is required, but I dont know. brand is required twice, why I dont know.)
paulmars
house
Ive watched several troubleshooting videos for this specific model troubleshooting for no heat. Each video tested the High-Limit Thermostat, Operating Thermostat, Thermal Fuse, heating element. One of the videos tested the timer. None tested or even mentioned the Thermal Cut-Off Fuse.
The thermal cut-off (thermal fuse) 360 degrees and high-limit thermostat 250 degrees.
The thermal fuse is a safety device designed to protect the dryer from overheating and catching fire.
It's very simple, you ohm test the thermal cutoff just like you would a thermal fuse. Same with the high-limit thermostat. Both should read 0 ohms when they are good.
paulmars
house
Before I purchase new cut off, I decided to test the two thermostats:
one is marked L155-25F. it opens at 110°F.
the other L250-80F. it opens at 180°F.
Some sites say that number after the dash is +/- for opening temperature. Other sites say that is how much less the temp needs to be for closing. I dont know which sites are correct.
You don't need to worry about temperature on these thermal fuses and high-limit thermostats, just as long as they ohm test good for continuity.:)
The L155 is the temp in F. it is designed to open at. It is set to close again once the temp decreases 155-25 = 130 close. 250-80 = 170 F. close. The 25 and 80 respectively is the temp. deferential between open and closing again. Cycling thermostats have a narrower differential than safety thermostats.
JFYI
