110.96575100 Kenmore Series 70 Soft Heat Extra Capacity dryer won't stop, timer dial doesn't move
JohnBailey
Ky
Kenmore Heavy Duty Series 70 Soft Heat Extra Capacity dryer won't stop, timer dial doesn't move.
As stated in thread title, the machine won't stop and the timer dial isn't moving. From another thread I assume it's a resistor but the other thread I found didn't mention anything about the timer dial not moving. Any advice would be great.
thanks in advance
Set the timer on timed dry about 40 minutes and on the back of the timer measure the voltage across BK and TM
If your meter indicates 120 Volts AC here's the part you need:
WP3398190 Timer
