- RFG237AARS
- Samsung
- More than 10 years
So I have an older Samsung french door that is not cooling effectively enough. It is a split zone model (I think called 'dual zone' cooling) which makes the freon lines coming from the compressor different looking than I find on instructional videos online. I have attached a tap valve on what I think is the line they use at the factory to initially charge the unit. Im wondering if this will work to tap into and run some 134A into the main body of the compressor.
Ive never done this before but it looks pretty straightforward. Im just not sure about where I have the tap valve located. Can anybody verify if this is a good location?
Before I pierce the line I want to know Im not piercing the wrong line. I dont have much to lose at this point because Ill have to get a new one anyways. The cost of a professional doing this makes it worth just buying a new one.
So is the tap valve in a good spot to replenish with 134A?
