Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: GE refigerator ice dispenser won't close
    Sep 2007
    NH
    Default GE refigerator ice dispenser won't close
    Model Number: GSS25LGMF
    Brand: GE
    I have a GE GSS25LGMF and the ice dispenser door won't close all the way. If I tap it, it will close. Can you help?
    Thanks, Marc
    Hi Marc,
    Its likely your ice door solenoid is sticking and will need to be replaced.
    Here is a link to help you access it, read last paragraph, where it says:GE's newest SxS refrigerator dispenser.
    http://www.applianceaid.com/gethroughdoor.html
    Here is the dispenser solenoid for your model:
    Dispenser Solenoid WR62X10055
    Sep 2007
    NH
    Hi Jake,
    that link doesn't seem to work. It says the site has been suspended. Is there anywhere else I can see these pictures?
    Ok, I forgot, Jeff said he had to move the photos to another server, Here's the photo's from the achieves: http://www.applianceaid.com/gethroughdoor.html
    Small flat screwdriver to pry/ease the bottom part of the key panel loose and out towards you...
    The key panel will come out towards you and ( with power off ) the wires are easy to unplug...
    Remove 4 star screws...
    The whole assy will easily come out towards you...
    You are there...
    Sep 2007
    NH
    Thanks Jake. It's working great now!
    Marc
    Excellent Marc, good job fixing it.
    Jun 2011
    Shelburne, VT
    Thanks to you and Jeff for the pictures. Gave me the confidence to tackle my stuck ice door. A little WD-40 and it seems to be working fine now but see it will be easy to replace the solenoid if necessary.
    Terry
    Excellent Terry, good job.
    Aug 2011
    New Jersey
    Default Remove dispenser flap & chute
    Will the diagrams and steps shown here also work for an Arctica Model PSS25SGNABS with a stainless door? I tried prying off the control panel (I think it's called the interface) as shown in the diagram above, but it doesn't want to come out and I'm afraid of snapping something. Do I need to remove the big black cover (Moulding) that goes around the whole dispenser on the door first?
    Nope, yours should come out the exact same way.
    Now I'm not sure if the stainless steel door matters, someone else may want to answer that for you.
    I know its a little Different on the GE monogram models: GE Monogram 36 S by S freezer leak at ice dispenser chute
  1. Soap dispenser won't close
    By jblue2 in forum KitchenAid
    Last Post: July 16th, 2012, 10:24 AM
  2. MSD2456GEB ice dispenser door won't close
    By resound in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: June 20th, 2010, 04:52 PM
  3. Soap dispenser does not close
    By mj662 in forum Bosch
    Last Post: December 23rd, 2008, 07:38 PM
  4. In door ice dispenser flap will not close
    By pgluckey in forum GE/Hotpoint
    Last Post: July 5th, 2007, 09:20 PM
  5. Soap Dispenser Won't Close
    By RJTODD1 in forum KitchenAid
    Last Post: February 16th, 2006, 02:21 AM
